XREF snapping crash
I'm not sure if this one has been posted before, but it is a major bug.I am using version 2.2.0025. Sometimes when snapping to an XREF, the program crashes and I get the message included below.This does not always occur -- I may have the same file XREFed into two different drawings, and in one drawing there is a problem, and on another it is not a problem (or so it seems). Please fix this! It makes the software unusable.---------------------------------------------ICAD caused an invalid page fault inmodule at 0000:00000009.Registers:EAX=0325fc34 CS=017f EIP=00000009 EFLGS=00010217EBX=0000000e SS=0187 ESP=00abed70 EBP=00abf458ECX=0416df20 DS=0187 ESI=03bb87d0 FS=192fEDX=00abf460 ES=0187 EDI=00000000 GS=0000Bytes at CS:EIP:00 a9 05 65 04 70 00 65 04 70 00 54 ff 00 f0 85 Stack dump:00000187 51d8d25e 00abf460 00abf850 03a70050 00000000 00000000 40200000 00000000 00000000 00000000 00000000 d47cb5ba 40bcbb5b 00000000 00000000 -------------------------
  • I've have been experimenting a lot with this trying to make it work better.It seems that the problem goes away (most of the time) if only the endpoint running snap is set. If endpoint and intersection or enpoint and perpendicular are set, then it crashes repeatably and predictably. I can send you a file that will reproduce the crash if you want it.Thanks.
  • Hello,We are aware of the problem and trying hard to understand what is causing this problem. Any reproducible scenarios can certainly help us in this proces.Please feel free to send me these drawing(s) including a short description on how to reproduce the problem.Kind Regards,Jeroen TheunsBricsnet Q.A
