XDWGFADE control on inserted xref (block)
Hi
I turned XDWGFADE to 70.
When i insert a xref (=>block) the display is incorrect
Have you tried using _Regen?
What does help is save it and open it.
FWIW: If I test this everything works as expected: the display of the block references updates immediately.
Only with DWG made in AutoCAD, 2D and 3D
No big deal, just a minor glitch.
