XREF visible but not accidentally selectable ?
Is there a way to show XREFs, like an underlaying 2D plan,
but prevent them from being selectable ?
I have the Layer locked but the XREf gets selected anyway when I
try to do any 3D Entity Selections
A workaround may be the use of the PDFs instead of DWG XREFS.
As these are snap-able and will be selectable at their border only,
so not disturb Selections much.But I have problems with PDF's accuracy.
They seem to be in a certain predictable scale minus the print border loss.
When trying to find a suitable scale and check by PDFs dimensions, it looks
like I could not find a proper scale that worked for all dimensions.Isn't there any hidden command that will lock or block entities from
onscreen selection ?0
