Bricscad V18 - entity selection question
Just upgraded to V18, and probably a setting is off somewhere.
In previous versions, without any command being active I could select entities on screen and they would appear with grips that could be moved, etc. Now with V18 when I try to select something before starting a command, I get odd white outlines around objects but nothing selected. How can I go back to the behavior of the previous versions?
Thanks.
Ok, sorry I described that wrong.
Actually, I can select something by clicking on it. What does not work is trying to select it with a crossing rectangle when no command is active -- then the white outlines appear. Is this a setting?
SELECTIONMODES (probably).
That was it. Thanks!
