Multi-Threading Flags ?
Are these thought to be activated,
or is there a reason why they are switched off by default ?
If you're running 3rd party applications, then parallel processing through MTFLAGS can cause problems. Obviously you also have to have a processor capable of multi-threading, which isn't an issue with modern machines. Other than that, I don't see any reason not to make use of MTFLAGS.
CAD Concepts0 -
For me it looks like I had a lot of crashes when I activated all
options at the beginning (Structure Browser, UI)
It worked much more reliable without after deleting Config.
And as I tried again, the UI seems to freeze for many minutes from
time to time. (Without RAM increase) While I can still rotate my view.And I see 2 other Multi Threading options (Whip Thread) with the
"not yet supported" flag.0 -
Hmmh, the UI freezing must be something else.
Happened with a restarted Bricscad without any Multi threading setting again.I will give multi threading another chance.
I have these activated again.
But beside Rendering, I still see only Single Threaded actions in Mac Activity Monitor.0
