Possible error of Bricscad
Hello, something pretty extrange has happened working with brcscad. I had a file in autocad 2000 with a block inserted, when i opened in bricscad the block was not in tis original position, I had the same block in other insertions but they were ok, it was only with this one, I erased and put again and it was ok. Any suggestions why this hapened? I put a picture. thanks
