View by UCS
Hi all,
Does anyone know how to to set the view by UCS? I am using BricsCad v.16
Thank you in advance!
  • Found it!
  • When you come up with a solution, it would be helpful if you post it for those who may be confronted with the issue in the future.
  • The PLAN command aligns the view with the XY-plane of the current UCS. The 'View' option of the UCS command aligns the UCS with the current view. If the UCSORTHO system variable is ON, the ucs automatically aligns with orthographic views (top, back, front, left, right, bottom). Orthographic views can be selected easily in the Look From widget.
