BAK Files ?
I do automated backups in a custom temp folder.
What is the use of additional BAK files beside the working file ?
Can I deactivate them ?
BAK files are duplicate backup copies of your file.
They contain the file state you previously saved manually.0 -
Can be deactivated in SETTINGS.
Search for "bak", you'll find:
"Incremental Save Backup". Uncheck "Create BAK file"0 -
Yes, I did deactivate them initially because they disturbed me,
but I was not sure if I will miss something by doing so.But still am not completely sure about Back-upping procedure
in Bricscad in general.In every other App I activated Auto Backup copies in case of crashes.
I set number of versions, time or number of commands and of course Paths
inside a common local fast SSD folder where I can look for them or clean up
from time to time if needed.
So if a file crashes and I missed to manually save sufficiently, I will find my
last saved file state there, open it manually and if ok, Save As working file.
(overwriting current working file)
Fine.In Bricscad I set my Save Path and it looks ok, *.BAK and *.SV$ are there.
(BTW what is that numbering scheme that does not sort in time order in Finder ?)
I decreased back up time to a reasonable value.
(expected it would be seconds, not minutes, when defaulting to 60 !)But how to recreate the last file state in Bricscad after it crashed and I missed
manual saving ?1.
Will it automatically care about *.SV$ when I reopen my working file ?
(looks like it will not)
2.
Should I manually open the *.SV$ and overwrite working file manually ?
3.
Should I open *.SV$ by "Recover" command ?
or better
4.
Should I open my working file by "Recover" command ?
(That Bricscad will consider the last *.SV$ ?)0 -
To recover a dwg saved as a .SV$, simply change file extension (from .SV$) to .dwg.
Same applies to .bak files.
You can check times of creation to find which file is the most recent.
Search help for .SV$, .bak which will help explain options re: system variables and user preferences.0 -
Thanks Robt,
so if I got it right,
when I saved my drawing at 2 pm and Bricscad crashes at 4 pm
and I know reopening my work file would lose 2 hours of work,
the recommended way to reduce the damage would be :to go directly to the *.SV¢ files and open the latest and manually
overwrite the work file with it (?)Yes, It needs to search through file creation dates, to find the
most recent *.SV$ file, as it currently is. That doesn't necessary mean
that there couldn't be more convenient solutions, in my opinion.0 -
I've found Bricscad to be very stable (possibly more so that AutoCAD), but nevertheless crashes CAN occur.
One thing I ALWAYS do (especially when working with .dwg s from others) is run AUDIT, PURGE before commencing.
If you do experience a crash, search for the latest file (.SV$ or .bak).
I would rename them i.e: drawing(1), drawing(2) so you can open them simultaneously and compare them.
Get in the habit of manually saving every so often (We've all been frustrated finding out that we forgot to save & lost ~30 minutes work).
May want to reconsider creation of .bak files.
Change SAVETIME variable to a more conservative value.0 -
Thanks Robt, now I know how to deal with (*.VS$) backups.
My crash experience may be slightly different, but I am
a) on macOS
b) using mostly latest 3D and BIM technologies available
c) Am new to Bricscad so may tend to use tools in a creative unforeseen way
that no one tried or tested before.
But it is not that bad.
So far no need to add a _qsave after each command
Cheers
We're all in this together...0
