BimRoom - `Failed to create a room' errors
New to BricsCAD, I am diving into V18 BIM and enjoying the speed, flexibility, and power of the 3D platform. I am having trouble, though, with the BIMROOM command, two issues in particular:
1) Seemingly enclosed rooms –
Rooms that appear to be fully bounded by BIM-classified Walls are sometimes not recognized, with the command giving a`Failed to create a room' error. Is there any way to gain insight as to why it failed? For example, if I have modeled a room with four walls and could know that BimRoom has detected, say, only three walls—even better, which three—that would help to identify missing walls or problematic solids. In a few cases, I discovered the culprit to be a small, otherwise unnoticeable gap where walls were supposed to connect; are there any gap tolerance settings, or detection tools?
2) Open-plan rooms –
What is the best way to define rooms that are open to adjacent rooms but that should be identified separately, such as a kitchen open to a living room? I see in the online Command Reference that BimRoom has an option, `Select 3D Solid', to create a room entirely defined by a solid, which I could create manually. However, this method makes a static room that cannot be updated, which seems to defeat the purpose.
I am having the same issues here (also on V18).
Surrounding walls also seem to be included for the area (and volume). I would expect the inside...
Did anybody found an answer to this? Without any it would be impossible to use rooms since there is not "manual" room definition.
Please file a support request and add the model your are having the issue with.
