Tool palette not docking
When I import my tool palette from autocad and shut down Bricscad, I have to re-import it each time.
Is there a way to keep it docked rather than having to re-import it each time?
Cheers
  • I don't know that tool palettes CAN be imported from Autocad.
  • Hi Jim you can actually import AutoCad tool palettes into Bricscad as explained in the ebook.
    I've imported the xtp file and the tool palette works fine but like I said if I close Bricscad and re-open it I then have to re-import the xtp file which is annoying.
