Is any other function for AcDbAssocNetwork in BricsCAD?
Dear friends,
I want to migrated the source for AutoCAD(2013) into BricsCAD(2018).In this project fully based on the parameter.
AutoCAD ObjectARX contains the AcDbAssocNetwork for Modify the drawing parameters ,but BricsCAD ObjectArx should not Contain the function for Modify the drawing parameters.so how to modify the parameters in BricsCAD and what function to use modify parameter.
Dear Vignesh,
You might get a better and faster reply on this if you send a support request.
Howdy, Stranger!
