Bricscad shutting down when using SprinkCAD
See event log below. This is happening every 30 minutes or so.
Talking to SprinkCAD also as the sprinkler software not functioning well. I am using latest SprinkCAD with V17 BricsCAD.
Log Name: Application
Source: Application Error
Date: 7/12/2017 1:07:49 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: pkossally-PC
Description:
Faulting application name: bricscad.exe, version: 17.2.8.48934, time stamp: 0x593e77e9
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc0000409
Fault offset: 0x0000000000074a30
Faulting process id: 0x21c
Faulting application start time: 0x01d36f75623a18ed
Faulting application path: C:\Program Files\Bricsys\BricsCAD V17 en_US\bricscad.exe
Faulting module path: C:\WINDOWS\SYSTEM32\MSVCR120.dll
Report Id: dbf6f706-b4bc-4c25-aeb6-7eb47765742c
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
1000
2
100
0x80000000000000
5850
Application
pkossally-PC
bricscad.exe
17.2.8.48934
593e77e9
MSVCR120.dll
12.0.21005.1
524f83ff
c0000409
0000000000074a30
21c
01d36f75623a18ed
If you want to relay this information to the Bricsys developers you should send in a support request.
Note that you are not using the latest V17 version.0 -
I am using BricsCAD V17 Version 17.2.12 (x64) revision 49652. I am still having issues with "ScrinkCad 3D" solid modelling not working. Solid modelling used to work in BricsCAD v16. See attached snip of errors, "Assertion failed".
I tried to revert to v16 BricsCAD but could not download since I have upgrade to v18. I will check with support to see what is possible.0
