CHSPACE scaling dimensions
Hi all
I'm a newbie using bricscad, I think is a very good sw and I'm using it mainly to exctract 2D views from others 3D modelers.
One of the commands that are very important for me is CHSPACE.
In autocad the command CHSPACE can scale drawing and dimensions too.
for example if I create a viewport with 1:2 scale and dimensions are:
scale overall 1(fit) -
scale lilnear 2 (primary units)
with CHSPACE command in Acad I obtain
scale overall 2 (fit)
and scale linear 1 (primary units)
with CHSPACE command in Bricscad I obtain
and scale linear 2 (primary units)
So, it's very complicate to manage and modify drawings with different scales and dimensions.
Hope for a solution, have a nice day
Can you file a support request? If there really is a problem inside BricsCAD our developers will be glad to look into it an find a solution.
Yes of course, how can I do it?
