overkill in lisp routine
I found an example of the overkill command used in a routine:
(defun c:Test (/ ss)
(if (setq ss (ssget ))
(progn (sssetfirst nil ss)
(vla-sendcommand
(cond (aDoc)
((setq aDoc
(vla-get-activedocument
(vlax-get-acad-object))))
"-OVERKILL IGNORE LWeight,Layer "
(princ)
But if I want to continue, I can't use the old selectionset ss. Is it possible to continue with a new selection set without the removed elements?
why did you cant use the old one?
I think you can check each item in this ssset if exists and if so, leafe it in the ssset, otherwhile remove the item of the ssset0 -
Thanks for your reply Martin, that sounds logic.
But I am more of a copy/paste/edit person when it comes to lisp... Not so great in writing new code
So please, can you show me how to do that? Or which functions to use?0 -
(defun c:Test (/ ss item)
(if (setq ss (ssget))
(progn
(command "-overkill" ss "" "Ignore" "lweight" "Ignore" "Layer" "")
(foreach item (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(if (not (entget item))
(setq ss (ssdel item ss))
(princ)
)0
