DATAEXTRACTION
Problem : Get the count of blocks in a set of drawings
Preferred out put
BlockName|Count
Door100 |100
Troffer01|15
WD02|23
Currently the DATAEXTRACTION command in Bricscad can only extract the block count in a set of drawings if I XREF all the drawings into a single drawing and then select all the drawings and run the DATAEXTRACTION command.
Am I missing out something here. Is there any way to get the block count of all blocks in a set of drawings in any other way in Bricscad. The current method is really tiresome because the folder structure of larger projects is quite deep and xreferences may be in many different place. It is very easy to miss a particular XREF.
Thank you all for any responses.
IMO there is a fundamental problem with your request:
A block in dwg A can be completely different from a block with the same name in dwg B.0
