LAYERS
I have a Trial VERSION OF "CLASSIC" ON page 91 of "INSIDE BRICSCAD" , THERE IS A Screen image of LAYERS. This is horizontal and similar to AutoCAD, But my Trial Version has them listed in a narrow band VERTICALLY, which makes it difficult to view and manipulate Also there is no indication of the various options . E.G.make this Layer current. EASY PEASY IN AutoCAD ,but not in Bricscad. Off-putting to a potential buyer !
Can you post a screenshot of your Layers List which is causing concern?
"Layer" command here has always worked as in AutoCAD.0 -
The Layers panel is an optional panel which can either be docked or floating. You can dock the panel vertically or horizontally. See the Command Reference under L/LayersPanelOpen to learn more about it. To set the current layer you have several options: Click in the Current column on the layers panel (= first column), click the layer name in the drop-down list on the Entity Properties toolbar, or right click the Current Layer field in the Status bar .
