Bricscad Tools Disappeared
Hi Guys. i got myself in a mess. I loaded the socofo tools and now my Bricscad tools have disappeared. It doesn't even appear on the Customize lists. Please help!!!
Type in CUSTOMIZE, then press "Revert to defaults..."
When loading the Sofoco Tools cui file, please use "Load Partial CUI" file, NOT "Load Main CUI File". If you load our toolbars as the main cui file, you will blow away BricsCAD's user interface.
@Damian Harkin Thanks mate. You got me sorted. Cheers :-)
