BIM-Lisp: stories and buildings
BIM example drawing "campus_complex.dwg"
(Prolog: it is not that easy to paste strings from comamnd-line to this forum)
I get this result:
: (bim:get-all-story-entities "Bldg2-East" "Roof")
Entity name: 3a0cec0 Entity name: 3a0d000 Entity name: 3a0c380 Entity name: 3a0ccc0...
Fine. This tells me that story "Roof" in building "Bldg2-East" has a lot of entities. Now I want to know:
: (bim:has-story  "Bldg2-East" "Roof")
nil
Not fine. It tells me that building "Bldg2-East" has no story "Roof"???
What's wrong?
  • Dear Peter,
    thanks for the hints ... such defects should also be reported as SupportRequest :-)
    Nevertheless, just fixed ... was a stupid typo in Lisp engine : if you switch "building" and "story" name, then it works;
    but only for testing, please.
    Because the fixed implementation will match the docs then ...
    many greetings & Merry X-Mas !
  • Thanks Torsten.
    So it will be released in the next V18-build?
  • Likely with some chances ... but as usually, no guarantee;
    I will post here, when it is included.
  • Torsten Moses
    edited December 2017
    Dear Peter,
    the fix is included in V18.1.09 :-)
    many greetings !
  • Thanks - I will check it.
