OSNAP DELAY
HOW DO I ADJUST THE OSNAP DELAY TIME?
THANKS
There is no osnap delay setting. I assume you have a situation where performance is too slow?
Maybe I am misstating the problem. Before V17, in order to track from an object, I would have to pause the cursor over the object. Now, the strack starts immediately when passing over objects, thus sometime tracking from unwanted objects. For example, I want to track from an object, but while passing over other objects, it will track from them instead of the object I wanted to track from.
Thanks for your help.0 -
I do not notice the delay you refer to when testing this on V16.
But maybe you are used to a different POLARMODE setting? You can try changing the SHIFT key behavior so that you have to hold down that key to acquire tracking points.
Of course the OSMODE setting and the APERTURE setting also have an impact here. So it may be worth looking at those as well.
My problem is not the delay, but the lack of the delay. Is this a change from earlier versions? As I said, previous versions required you to pause the cursor over an object before it would start tracking. This way, you wouldn't track from unwanted objects. I can track from and object but when passing over other objects it will automatically start tracking from them - not the object I want to track from. It is very annoying. I'm sure I can't be the only one having this problem??
