Hatch BIM Surface
in 3D Modeling
Hello, trailing BrisCAD BIM for architectural drawing purposes.
One question I have regarding material representation.
Image an elevation showing a brick wall, I understand I can apply a 3d material show its representation.
I'm wondering if it's simple enough to apply a brick hatch to it instead?
Cheers,
The Materials assigned to Composition‘s Plies have a Hatch
for cut faces of the section and a Render Material for solid‘s
faces.
If you want a Hatch appearance for the whole Solid in renderings,
I think you need to create a new Render Material with an Image
Texture that looks similar to a hatch.
To create one you could assign a hatch to rectangle and screen shot
or draw one in Photoshop.0
