BricsCAD to Revit (IFC)
When I import your IFC model in BricsCAD everything seems all right. Also the Solibri Viewer imports the model correctly, so it might be Revit related. Can you please file a support request and add the IFC model?
I can't tell you why, but I can give you a big clue. In revit the door opening is 67 21/64" convert that to mm and you get 1710 guess how big the door is 1710"
Thanks Louis & Steven
I got some feedback(autodesk)
Because the IFC_door、IFC_window import to Revit.
It's ignore some scale parameter,So...0
