Migrating from Trial version to Pro version
I have plans to purchase a full working version of BricsCad Pro for 2D/3D drafting in the next couple of days before my trial version time runs out. I have extensively customized the trial version and changed several default settings. Some of my customization is located in User/Appdata/Support/etc. Some is in Program Files/Support.
When I buy, will I be able to authorize the trial version or must I completely reinstall a separate version? I would not like to have to completely reconfigure all the files and settings on a licensed Pro version.
The only requirement to move from trial to permanent version of BricsCAD is to enter a valid license key. There is no need uninstall/re-install.
I would recommend that you consider keeping your customisation in a separate location. This makes it easier to maintain, and re-use when upgrading to future versions.
CAD Concepts0
