CMake plugin build
I tried to convert to CMake project.
But i'm getting an error during addin loading.
Am i missing something?Here is cmake project:
cmake_minimum_required(VERSION 3.9) project(brxAdd) #set(CMAKE_CXX_STANDARD 11) include_directories( $ENV{BRX17_SDK_PATH}/inc $ENV{BRX17_SDK_PATH}/inc/Platform/substitutes ) add_library(brxAdd SHARED Sample.cpp acrxEntryPoint.cpp StdAfx.h StdAfx.cpp arx_version.h sys_version.h resource.h cmd/cmdDbx.h cmd/cmdDbx.cpp # cmd/cmdCom.h cmd/cmdCom.cpp # cmd/cmdGui.h cmd/cmdGui.cpp dbx/MyEntity.h dbx/MyEntity.cpp dbx/MyOPMExtension.h dbx/MyOPMExtension.cpp ) target_compile_options(brxAdd PUBLIC -O2 -Wall -std=c++0x -frtti -fno-signed-zeros -fvisibility=default -fPIC -Wno-sign-compare -Wno-sign-conversion -Wno-empty-body -Wno-reorder -Wno-parentheses -Wno-switch -Wno-unused-parameter -Wno-unused-function -Wno-unused-variable -Wno-unused-label -Wno-unknown-pragmas -Wno-comment -Wno-strict-aliasing -Wno-unused-but-set-variable -Wno-unused-value -Wno-attributes -D_UNICODE -DUNICODE -DNDEBUG -D_AFXEXT -D_ACRXAPP -DBRX_APP -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES ) set_target_properties(brxAdd PROPERTIES SUFFIX ".lrx") link_directories( $ENV{BRX17_SDK_PATH}/lib64 ) target_link_libraries(brxAdd PUBLIC -Wl,-whole-archive $ENV{BRX17_SDK_PATH}/lib64/libdrx_entrypoint.a -Wl,-no-whole-archive ) target_link_libraries(brxAdd PUBLIC $ENV{BRX17_SDK_PATH}/lib64/libbrx17.so $ENV{BRX17_SDK_PATH}/lib64/libTD_Alloc.so $ENV{BRX17_SDK_PATH}/lib64/libTD_Root.so )
We have no CMake sample for a BRX application.
Please enter a support request, and re-attach your CMake code there.
Internally we can more practically track support requests, assign to appropriate analyst/developer...
(That said, this forum post can still be useful in case it rings a bell to someone in our user's community.)But i'm getting an error during addin loading.
What is the error message you are getting?
Did cmake generation/ compiling / linking pass without error?From a glance I see nothing out of the ordinary, but I am no brx specialist.
For a start, can you try running BricsCAD in a terminal and/or in a gdb session, there might be a useful error message on stderr. -
Have you tried whether the CodeBlocks-generated .lrx module does work ?
Or does it also trigger same error ?If it loads, then there seems to be some details missing with the CMake build ...
but if it loads with same error, then we need to have a closer look at the CodeBlocks sample as well
(though it always worked in our internal testing).many greetings !
Thank you for your replies!
I built and loaded CodeBlocks-generated .lrx module without any problem.
Then i tried to convert it to cmake based project.CMake project build passed without errors.
Then i tried to load .lrx addin build using cmake and i'm getting this message:
: _appload
Loading /home/alexey/CLionProjects/brxAdd/cmake-build-debug/brxAdd.lrx
Error loading "/home/alexey/CLionProjects/brxAdd/cmake-build-debug/brxAdd.lrx": .
/home/alexey/CLionProjects/brxAdd/cmake-build-debug/brxAdd.lrx loading failed.Not sure what i've missed. Could you please review the cmake project.
Here is project (i've converted brxSample example):
I've also submitted a request
Howdy, Stranger!
