Rotated crosshairs and dimensions (9 degrees cw from square/ortho)
Greetings all,
I have tried searching for the answer and tried a few setting changes with no luck, so here I am (hopefully in the correct place)
I received a 2d dwg drawing from a third party.
On opening, (BcadV17), the crosshairs are at 9 degrees cw, the dimensions and text also are at 9 degrees cw, the question is, What setting needs putting back to 0?, i thought it was 'snapang', but that only sorts the crosshairs and not the dimensions. Normally, I can solve these problems, but i'm just not sure what i'm looking for........ (im more mechanical than architectural)
Any advice is appreciated,
(i'm hoping it is not an iD10T error!)
regards,
Mg
Try one (or both) of the following:
UCS command, then Enter twice to restore the WCS.
PLAN command , then Enter twice to restore the Plan view of the WCS.
If this doesn't solve the problem, file a support request and add the drawing.0 -
Maybe reset the UCS to World?
_UCS _World0
