Sofoco Tool
Hello,
After exporting Sections and Plans from my Bim Model I am trying to oder the layers to our 2D standards. I heard in AutoCad there is the Layer Translaate / Mapping option. With BricsCad I didnt found anything like that and I tried to download the Sofoco Tools to use the "Lay Map" feature.
I have installed it according to the given indication and I see the tool in my BC. When I try to use the "Lay Map" command it tells me "no CAD system found" and than "SfcTools has stopped working" window, when I press "close program" the program stays open but the problem persist. If I try to use other commands I only see the first "no CAD system found" error but then the command seems working properly (at least I see a new pop-up window of the command).
Does anybody experienced the same?
I'm also interested.
