eTransmit just from loaded xrefs
It is already possible to remove attached Xrefs from the export list. By default all Xrefs are selected, you can then click the selection box to remove.
Thank you Louis,
I've just realized I made a mistake, too much stuff going on today in the office.
You've got the point. Obviously there is tick/untick list.However what I meant could the export list be "by default" coherent with unloaded xrefs list so I won't have to manually untick stuff?
