FATAL ERROR AT DEFAULT.CUI
Hello,
This error seems to indicate that your (local) 'Default.cui' file got corrupted somehow. You can always try to copy a 'fresh' (un-corrupted?) version from the Programs directory (UserDataCache)
to your local Roaming users directory:
For a 'en_US' 'x64' 'V18' version this would be: copy 'source' to 'target' with following paths:source:
C:\Program Files\Bricsys\BricsCAD V18 en_US\UserDataCache\Support\en_US\Default.cui
target:
C:\Users\\AppData\Roaming\Bricsys\BricsCAD\V18x64\en_US\Support\Default.cui0 -
Thank you Ferdinand Janssens. Your instructions worked.
I seem to have this problem (well had). I was trying to create a new profile cui, and thats when it ended up in a vicious circle. Restarted and its fine now, but I would still like to save my own profile with custom settings etc.
I am coming from AutoCAD (who isnt, right?) after over 20 years with them and I'm set in my ways. I'm working on setting up BCAD so I can work much easier and faster, so I dont want to have to do this again due to an error.
Thanks
AB0
