creating shortcuts
like in autocad we can create a shortcut for opening a folders please refer the attached snap3 file,
can we do it in bricscad because for me its not possible.
    nobody has solution for this, i think so ???
  • Anthony Apostolaros
    edited January 2018
    I don't think Bricscad can add extra folders to the Windows "Places Bar," as Autocad does. But it can change one of the 5 folders that Windows provides in that bar. The change will also affect any other program that uses the Places Bar.
    To change that folder, use the DrawingPath variable. The easiest way to do that is in the Settings dialog -- open the Settings dialog and type "drawingpath" or "places bar" to search for it.
    You can customize all 5 folders in the Places Bar by using the Windows registry, or by using a program such as Melloware Places Bar Editor (freeware).
  • You can add folders to the content browser
  • thanks
