weird things when mirror an annotative block
the objects make a double symmetry
Can you post a file showing this, or possibly a screen shot explaining the steps you went through so someone could recreate the issue, and see if it can be fixed.
He de decir que los bloques son "anotativo" y en autocad la simetria la hace bien
I have to say that the blocks are "annotated" and in autocad the symmetry does it well
