C# - set system variable
How do I set a value to the system variables USERR1 - 5 in C#. Can't get object.SetVariable Name, Value
implemented.
It's OK. Found it:
Application.SetSystemVariable("USERR1", pt.Y);
If you are creating an application and want to store a 'real' in a dwg I advise you to use a different method.
Use a dictionary.
FYI, there's nifty place for storing temporary data, its per document.
Hashtable Document.UserData
example:
Document doc = Application.DocumentManager.MdiActiveDocument;
doc.UserData.Add(KEY, VALUE);0 -
Thanks Daniel. Didn' know this possibility. They aren't lost when you close the file?
sorry, yes they are lost, as Roy mentioned a dictionary might be your best bet.0
