why can't I edit 3D poly lines in the properties dialogue anymore
I used to be able to edit the vertex elevation of 3D polylines in the properties dialogue now I can't all it gives me is the length and min max elevations. Is there a sys var I might have unknowingly changed?
Many thanks,
Ben
In the Properties Bar expand the 'Vertex' node and then the 'Position' node.
