CTRL+C CTRL+V Coordinat problem?
After selecting it with CTRL + C, I say CTRL + V then the right click coordinates of the mouse is different, which is the solution of this problem in the beginning?
If you only use Ctrl + c then Bricscad chooses a default point as the base point and this is used when you try and paste the object.
If you use Ctrl + Shift + C then Bricscad will ask you first to pick a base point and then this will be the point used when you try Ctrl + v0 -
Is there also a way to place a selection copy at the same place ?
I mostly want this and when I CMD+C CMD+V I always type in 0,0,0.Is there a CMD*D for duplicate or a CMD+SHIFT+V for a "paste in place" ?
To paste the selection to the original coordinates just press Enter when you are prompted to specify the insertion point.
There is also a 'Paste to original coordinates' option in the Edit menu.
The default base point for a selection set is the bottom-left corner of the bounding rectangle of the selection. Therefore, if you type 0,0,0 as the insertion point, the selection is not pasted to the original coordinates.0 -
"0,0,0"
That's what I feared.
Will a RMB click do the same as an ENTER in this situation too ?0 -
Michael reread Louis's post, just pressing Ctrl+c and then Ctrl+v followed by ENTER will paste to the original coordinates, even between drawings
Yes, I just realized that my input workaround went to file origin.
Which ws nearenough to not recognize but wrong.
I will either get used to the Enter or code that paste in place into
my Enterprise button.0 -
Got it.
It works for the Enterprise button macros to "paste in place".
But meanwhile I think the standard
"past and glue to cursor by insertion point to place by next click"
isn't that bad either.0
