Mtext Export to Txt., location referenced (From 2D to 3D)
in 2D Drafting
Dear all,
I'm having a drawing full with M-text numbers.
I would like to export the value of the text and his location to a .txt or .dta-file.
So i can use the value of the text as the height for this point location.
Does somebody has a LSP or a way to do this?
Greetings and thanks in advance
If you select all the items then dataextract will give you a csv file which is basically just a txt file and you can tell it exactly what information you want to extract such as the mtext contents and the x and y positions
