greetings~~~,
Due to the short cut reason, i would like to change my software interface language to be English, do I need to uninstall the software completely and reinstall the English version? or is there any convenience way to achieve my goal?
Thanks in advance~
As far as I know, you should be able to run multiple BricsCAD instances on the same computer, but need to download and install the English version of the software to get English user interface. Users that have bought other language versions than English, can also install the English version with the same license key.
@Per Gogstad
Thanks for your help, It works, thank you very much~
