text height in my Mleaderstyle
the text height in my Mleaderstyle is max. 100. Even when my text style is 200 ! And when I changed the height in 200 and used this command, it goes imidiately tot 100. I try everything, but no result ............??
An MLeaderStyle has a scale property (see the 'Leader' tab). You should configure a style as you want it to appear in print, and then set the scale as required. Having said that, I do not understand the GUI limitation you have encountered. Programmatically the text height is not limited to a max. of 100.
