German Help File - it needs help
Was the German Helpfile checked by a someone who understood one of the basic features of this language: The concatenation of nouns?
Reading the doc causes bad headache:
"Schnitt Ebene" instead of "Schnittebene"
"orthographisch" instead of "orthogonal"
"Schnitt Ebenen Objektes"..
"Griff-Bearbeitung"
"Zeichnungs Explorer" instead of "Zeichnungsexplorer"
"Live Schnitt Einstellungen"
Please help the help file ..
I tested the German Localization a while ago and also noticed
many translation problems - in the Settings Dialog.
(And Tools/Menus ?)
These were mostly technical terms where we use different or
special own terms, instead of a 1:1 translation english>german.Don't find an Example in help file,
maybe they alreade worked on it
For technical descriptions I think that is ok.
At least if it is about combining more than 2 nouns.
I think Koordinatenreferenzsystem doesn't make
it any better readable or easier to understand.I see it like independent names or terms.
"Die Bundes Regierung will nach den Koalitions Verhandlungen Steuer Erleichterungen für Fabrik Arbeiter und Haus Frauen durchsetzen, aber Diesel Fahr Zeuge verbieten."
Na ja - mal schauen....0
