BIMSECTIONUPDATE for non-Bim-Sections?
I'm trying to (semi-)automatise the creation of sections and "DWGs from sections" with AutoLisp.
I could create "Sections" and define the "Destinationsfile" in the "SectionSettings" - that's fine. ![]()
When I start "sectionplanetoblock" I got the dialogue with destinationfile and all that stuff, and "OK" creates the file - that's semi-fine. ![]()
When I start "bimsectionupdate", then nothing happens - I suppose because my sections are no BIMSECTIONS. That's not fine :'(
So what has to be defined in the "SectionSettings" that it is recognized as BIM-Section?
Thanks in advance!
Peter
Have you tried using the bim:set-bimtype function from the BricsCAD BIM LISP API? I can't test this myself as I do not have a BIM license.
Thanks for the hint. This could be helpful for other projects, but this code must be run under basic Bricscad.
I did have a go at using 'vanilla' Lisp before posting my previous answer. I have tested in V16 BIM with a dwg that already had a BIM section. The result of the code is a BIM section that looks correct but somehow the 'DB_MANAGER' link is not applied [See (cons 330 dbMan)]. In general the BIM stuff in dictionaries is not accessible in vanilla Lisp.
(defun Get_DB_MANAGER ( / dict spc) (setq spc (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) (if (and (= :vlax-true (vla-get-hasextensiondictionary spc)) (setq dict (vle-dictobjname (vlax-vla-object->ename (vla-getextensiondictionary spc)) "BIM_DATA")) ) (vle-dictobjname dict "DB_MANAGER") ) ) ; (cdr (assoc 330 (entget (cdr (assoc 330 (entget (car (entsel)))))))) (defun c:test ( / dbMan enm) (if (and (setq enm (car (entsel))) (= "SECTIONOBJECT" (vle-entget 0 enm)) (setq dbMan (Get_DB_MANAGER)) ) (entmod (list '(102 . "{ACAD_REACTORS") (cons 330 (entmakex (list '(0 . "BimDbSection") (cons 330 dbMan) ) ) ) '(102 . "}") (cons -1 enm) ) ) ) (princ) )0
