Block redefine dialog not showing
I don't know what I fiddled with (I have been trying out some new lips routines) but now when I try to add a block from the Drawing Explorer that I have previously inserted, I now get a command line message "The block ECMA B1004 Foldover edge with webs already exists. Do you want to redefine it? [Yes-Redefine block(Yes)/No-Do not redefine(No)]
as opposed to a dialog box.
How do I get the dialog box back?
Many Thanks in advance.
Either CMDDIA or FILEDIA (or both) got reset to zero. Set them both back to 1.
Owen,
Thanks for the quick reply.
Unfortunately I already had these set to 1.
I have subsequently noticed that if I type "Insert" and navigate to the file the dialog displays as it should.
It is only when I use the Drawing Explorer and right click on the file and "insert drawing as block " that the command line displays.
It could have always have been like this, but I can't recall.
