HELPwith paperspace
Hi, one of my users have zoomed into a viewport so she can not see the edges then doublelicked. Now we are stuck and can zoom without seeing the edges. How do I get out.
Patrik
Type 'ps' followed by enter, or there is an icon at the lower right of the screen M:Layout1 (or named after your layout) clicking that should toggle you back to paperspace, where you can then zoom extents to get back to normal
Thx I had unchecked that one as I hardly ever use paperspace. I this case I had a big 2D model that did not fit in one paper.
You can also Undo until you see the edges of the viewport. That way you return to the original viewport scale factor too. And then lock the viewport so it doesn't happen again.
