V18.2 bug: Set by layer doens't work in Properties after V18.2 update
When i draw a polyline or line (standard layer 0, linetype is Continuous) and i will change/override the linetype in Properties from By Layer to Continuous or another linetype, i can't set it back to By Layer. Also, at first, when i select the line or polyline and select the pull-down line in Properties automaticly shows Continuous.
All here above wasn't there when i used V18.1. I only installed V18.2, didn't make any other changes.
File a support request...
Hi semeg
I tried to reproduce that in my freshly installed V18.2.04 (x64) revision 52814, using my modified "default-mm.dwt" templateWell it seems to be working on mine. ;-)
