Path array
I cannot figure out how to align the 3D items on a path. It seems work with 2D but not 3D.
The UCS has an impact on the result of the _ArrayPath command. You should first align the UCS with the plane of the path. I do not understand the logic behind this behavior.
It is weird that UCS affect the alignment of array objects. I cannot find anything about ucs in ArrayPath online help.
https://www.bricsys.com/bricscad/help/en_US/V18/BricsCAD/index.htmlI have to change the ucs to world in order to make it work.
