Can't edit distance constraint in mechanical browser
Hi All,
I tried creating a box and appling a distance constraint with _dmDistance3d. I applied to two edges. I can't seem to change the expression. Edits in the lower pane to "Expression" go away when I select some other item in the mechanical browser. I am running 18.2.05 Platinum under Windows 7.
"box with constraint.dwg"
In the above file use a parameter "v1" as the expression. But, the problem is the same if I type a literal constant for the expression.
How can I change a constraint expression?
Never mind.
The problem was how I was leaving the Expression field. I was clicking on some other item or using Tab. What is necessary is to use the Enter key. Using the Enter key solves the problem.
