Workflow Timer
Is it possible to set a timer on a workflow, not for a specific action, but for the whole workflow.
The timer of the workflow should be set on f.e. 2 weeks, and every actor in this workflow has to react within this time. If anyone is too late, the status should automaticcaly change.image
