Images under entities are moving around while zooming
This can only happen in perspective views where the entities are not in the same plane ...
If this is not the case, can you please file a support request and add the drawing you are having this issue with. Our analysts will be glad to investigate.
Rendering if its set on 2D Wireframe then is ok
Howdy, Stranger!
