Arc Point, Angle, Point
Hi there
I'm on V18.2
I need some help while drawing an Arc with the predefined option point/angle/point.
I put my first point, after that i entered an Angle (lets take 3°) now i want to select an point on the right side (~45°) from the first point.
I always get an bulge faced down. How can i get the bulge at the other direction (face up)? Angdir won't have an impact.
Thanks Guys!
Martin
Sorry i'm not meaning point angle, point
I'm meaning point, radius, point0 -
Since you apparently have the 2 end points to snap to, why not pick the one on the right first? That will make the arc bulge upward.
Thanks, Anthony, but
my arc is starting at this point and i have to go this way.0 -
Quick and dirty:
Rotate the UCS 180 degrees around the X or Y axis before starting the _Arc command.0
