Mtext settings
Hi am I missing something or is something missing ???
We have not used Mtext to any extent but now I'm about to update some templates .
I'm interested in using multileaders but I want to have a smaller line spacing than standard. I started to look for the mtext styles but I can not find any.
Do I have to manually edit this every time ?
bump
Would that not be controlled by the MLEADERSTYLE (Multileader style) landing gap value in the content tab of the style definition dialog
(Or got to Drawing Explorer>Multileader styles and then on the content tab at the bottom section there is an area called leader connection where you can set the landing gap.
From the help pages:
Landing gap: Defines the distance between the landing line and the Mtext or the space between the Mtext and the text frame.(Assuming this is what you are looking for.)
Not really that i figured out but Im more interested i MTEXT settings there seems to be no way to preset them.
Things like linespacing etc.0
