3D part in 2D drawing
in 2D Drafting
Hello i work in 2D only. I am new and i trying the Bricscad as alternative to Autocad. I copy the 3D part to my drawing. The view start rotating and zoom out after mouse over on the 3D part when i want to rotate this part only in 2D, Is there any way how to turn off this feature? Thank you.
There is a link for video with problem.
¨https://youtu.be/lQ6-BfJz43M
@Jakub:
This is caused by a combination of two settings:- Dynamic UCS is ON. To change this click on the DUCS control in the Status Bar (below the drawing area).
- UCSFOLLOW is ON. You can change this by entering the variable name in the Command Bar, or by searching for this name in the dialog of the _Settings command.
