Seeing " instead of a Ø symbol.
in 2D Drafting
Hello,
I'm trying to open drawings exported from Tekla Structures.
But no matter what combination I use to create the diameter symbol, in Tekla, after opening it with BricsCAD it will only show a ".
I know I could fix this with changing System Locale but this will mess up the other letters.
When recreating the symbol inside BricsCAD it works. The symbols also work on a coworkers Autocad with same Locale.
Any thoughts?
Thanks!
