Trim a Wipeout
in 2D Drafting
Hello All,
is it possible to "Trim" a Wipe-out?
I have drawings from a client that need to be altered and the Wipe-outs they have created have hundreds of nodes so rather than manually relocating many of the nodes I
thought I'd try the trim function but was unsuccessful, does anyone know of a quick method of doing this?
TIA.
I doubt it but as a workaround could you use the boundary command and create a new polyline boundary using the trim object and existing wipeout area, and use that to create a new wipout of just the area you need.
