Keep Layer(s) selected when switching Viewports
Is there a way to keep Layers selected (in the "Layer" Window) when
working in different Viewports? Right now the selection gets lost when
I change the Viewport. Maybe this is controlled by some Systemvariable?
Austrobass,
Can you clarify what you mean with 'keeping layers selected' when switching viewports?
Did you check out if setting up a filter in the LayerControl can't do what you want.
